Hi hope someone can help me here please !
Im recently having problems when probing a bore using my Haas mill
The machine in question has had some accuracy issues so had Haas in and they ballbar my machine and it is now good also had the alignments checked and adjusted to suit !
The issues I am getting is when I probe a bore to set my work offset after calibrating it as per the Haas Calibration Routines
I then check my work offset using a DTI Clock I find it out and the parts I produce will be scrap !
Has any ever come across this problem before and found a way around it ? is there a different cycle a more accurate one I need to use ?
Any help would be much appreciated
Russell
