SIN-650S metal moulding machine
This metal moulding machine is mainly used for stone ,brass and aluminum sheet processing ,mould processing, wood processing
what it is used for?
This metal engraving machine is suit for making metal mould and wood mould,
art craft,dial,3D word ,PCB, stamp, relieve ,and signs.
What is it main features ?
--with TANWAN square orbit and solid blocks.
--2.2KW spindle constant power.
--imported ballscrews .
What is it advantages ?
1.whole cast steel machine body,Servo motor,powerfully milling,1/100mm precision.
2.Pause, adjust speed and cutting depth anytime during cutting,
Convenient for engraving different materials, applicable to different industries.
3.Well-compatibility: compatible software CAD/CAM, such as type3/.etc.
4.Heavy loading, non-deformation, adopting imported double-nut screw
5.Adopt high-speed water-cooling variable frequency motor, big torque,
strong cutting, high-frequency, long-life,
