Hello!
I'm working on a hand guided linear motion project (similar to a duplicator) and I'm curious what type of tolerance I would need to hold for my linear rail alignment if I wanted to use hiwin profile rails? Accuracy is fine if it's anywhere under .050 so we're not talking super tight here, I'm mostly concerned with the ease of which the system can be pushed around by hand.
Also, would you have any suggestions for a linear rail substitute that can span 12' in one shot if the profile rails require too tight a tolerance?
Nathan
