OK, so you have built a very cool router that does amazing things. I would think it would be fairly easy to hold down plaques or cabinet doors while your router works on them.
However, what if you want to make allot of small things at one time? I was thinking about making pistol grips for guns. I was thinking about cutting 10-20 of them at a time from one large piece of hard wood. When the router cuts through the wood to make each one it seems to me they would go flying. Hmm.....
I don't think a vacuum table would work because the parts are small (not enough area for suction).
I guess I could have the router to drill the two screw holes for each pistol grip and then actually use screws to hold it down to the sacrificial table while it completes the job.
Besides vacuum, screws and clamps, is there any other process that might work to hold things down?
