Hi
I have a Fadal VMC 4020 machine with FADAL controller. It worked fine, but few days ago, when I turned it on it appeared on the screen:
"Error While Processing Block 0". It always appears since then and I can't use the CS command and work.
I have tried to use RI command to reinitialize memory but it didn't work. What could be wrong ?
Any advise or suggestions what should I do next ?
