585,991 active members*
4,544 visitors online*
    Jan 2010
    26
    Mach3 Problems.
    I've been using Mach3 and a ZenToolworks 7x7 for a number of years. Recently my system crashed for good. I managed to recover my software and files and transfer them to a new system however now I a few problems.
    1, I can not jog at all in Mach3
    2, My system does not appear to be sending commands to my controller board.
    I have not played with these in 3 or 4 years so I do not remember how to set these things up.
    Any help getting my machine back up and running would be great. I need to start some engraving work for the holidays.
    Do you have the correct port address, and all the correct pin #'s assigned?
    Jan 2010
    26
    I believe so. I should say I was Jogging the new system without any movement from the machine but I reinstalled basic info from Mach3 per their website and now I can not jog at all. Set to 378. I did notice that when I have the PC off and the controller card on when I reboot the PC the card has 3 lights that go out that signifies it is getting a signal at start-up but the program is not talking to it. I have that m77,,, file setup.
    Anyone have an untouched copy of that Mach3 setup file? I do remember I had to play with the port settings on the old system but I again I set it and left it alone about 3 years ago and have only had this problem since I switched everything over to the new system.
    Feb 2007
    4553
    Astainless,
    Are you using a TB6560 stepper driver board that was provided with the machine?
    Jeff...
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Jan 2010
    26
    Ok.. I don't know what happened but after a 3rd reinstall of Mach3 everything is now working 100%.
  1. Another one who has problems with TB6560 in Mach3 :)
    By MLadegaard in forum Mach Software (ArtSoft software)
    Last Post: 10-01-2012, 09:00 AM
  2. Mach3 Arc Problems
    By dynamotive in forum Mach Software (ArtSoft software)
    Last Post: 12-13-2009, 12:49 AM
  3. C10 / Mach3 Problems
    By 2_many_hobbies in forum Mach Mill
    Last Post: 03-01-2009, 06:36 PM
  4. G02 - G03 Problems with Mach3
    By tiwanacote in forum Mach Mill
    Last Post: 01-19-2009, 11:53 PM
  5. Mach3 SpecialDriver.dat problems. help?
    By John Green in forum Mach Mill
    Last Post: 09-18-2006, 01:16 AM
