586,000 active members*
5,016 visitors online*
    Dec 2013
    Post First CNC Hot Wire Foam Cutter
    Hello everyone,
    I would like start building my own radio controlled planes so I deciced to take the big step and go for a CNC Wire Foam Cutter Machine.
    I have searched over the internet for parts and have put it together in this PDF file:
    Click
    I am new to this so I would appreciate the help very much!
    What do you think about this kit, is it worth the money/quality?
    I have multiple choices for some parts, so I put 'Or' between them.
    Budget is around €600.
    All suggestions are more as welcome!
    Thank you,
    TiboJ
    Dec 2013
    Anyone?
  1. rigid wire foam cutter
    By drzach in forum CNC Wire Foam Cutter Machines
    Last Post: 07-03-2012, 01:12 AM
  2. CNC hot wire foam cutter and USB controller
    By Kroko in forum CNC Wire Foam Cutter Machines
    Last Post: 08-23-2010, 07:29 AM
  3. Foam wire cutter needed
    By turmite in forum Employment Opportunity
    Last Post: 12-24-2009, 04:12 AM
  4. Best wire for foam cutter ?
    By fomaz in forum CNC Wire Foam Cutter Machines
    Last Post: 12-22-2006, 09:17 PM
  5. CNC Hot wire Foam Cutter
    By Krashlnd in forum CNC Wire Foam Cutter Machines
    Last Post: 01-17-2006, 02:57 AM
