i need some pull studs made
they are very similar to typical BT30 pull studs, just a few thou different in length and diameter. see drawing.
im not completely sure which steel they should be made of....please suggest. i would something like 5155 hardened to RC 56 to 58 would work.
if you can machine them but not harden or heat treat them that might be okay, i might be able to find some way to get them heat treated elsewhere.
hobbyists are welcome! if you are wondering you can make these on your manual mill, you might be able to if:
-you can maintain 0.0005" runout on a part 1/2" max diameter and about 1.5" long
-you can cut 5155 or similar steel
-you can make M12 x 1.75 threads with the same low runout as the rest of the part
-you can make chamfers
otherwise, a CNC would make it easier I believe
how many i will buy and at what price is totally up to you! please PM me your quote!
if you are a hobbyists and can only make 5, that might work!
it also might work if you are a business and need to make 100 to make it worth your while!
heres the drawing.
