Hi all
I am nearly done with my 3 axis router|mill. I`m thinking about using a router motor instead of the current setup which has a plate of aluminum which has the motor, motor mount and spindle all attached. I`m looking for the most accurate way to drill and ream some alignment pins into this assembly. If done correctly this should allow me to change from the spindle to a router and maintain some repeatability for the spindle.
I`ve been to MSC to locate tapered pins and the correct reamer to match. Can`t seem to find any tapered pins...does someone have a source for these items.
Thanks alot!!...Barry
