585,982 active members*
4,690 visitors online*
IndustryArena Forum > Mechanical Engineering > Mechanical Calculations/Engineering Design > Design question regarding ballscrew and bearings
    Dec 2013
    12
    Hi
    This is my second post, including the welcome post
    I have been reading the forums alot, especially the huge post the one user made to explain ballscrews. I can't find the URL now
    I am designing a machine and I was wondering if the ballscrew shaft needs to sit flush with the BK bearing or is 1mm distance fine? I would prefer 1mm distance, because I don't know if the rest of the machine will be cut, from t-slot aluminium, as perfectly as the shaft
    The pictures might explain better what I mean
    In this image the shaft has been machined in the recommended way by the supplier. The shaft goes from 20mm down to 15mm down to 12mm. My question is, does the 20mm part of the shaft need to touch the bearing inside the housing?
    Attachment 213212
    This is the image zoomed in a bit
    Attachment 213214
    Thank you
    Nov 2010
    520
    Well I'm hardly an expert, but I can tell you my experience. I purchased my ball screws and supports from Misumi. Included was a sleeve that went in between the (in your case) 20mm and the bearing in the support. And then on the opposite side of the bearings is another sleeve and then a lock nut to capture the ball screw in the bearings.
    I hope this makes sense. Here is a link to the ball screws I got from Misumi.
    Rolled Ball Screw - Thread Diameter 15- Lead 5,10 or 20 - Precision Grade C7 or C10?MISUMI?Product Specifications
    Rick
    Dec 2013
    12
    Cool. So if there is a gap after assembly I might just print something like a sleeve or a big washer to fill the gap
    Nov 2010
    520
    That would make sense to me.
  1. Replacing Y axis Ballscrew/thrust bearings.
    By steedspeed in forum Haas Mills
    Last Post: 06-28-2014, 09:24 AM
  2. Ballscrew support with ABEC 7 bearings... worth it?
    By erikjgreen in forum Linear and Rotary Motion
    Last Post: 10-09-2011, 08:01 PM
  3. Position of thrust bearings on ballscrew
    By M100 in forum Linear and Rotary Motion
    Last Post: 08-10-2007, 05:25 PM
  4. Bridgeport Ballscrew bearings, lock nut and end block questions
    By futura in forum Bridgeport / Hardinge Mills
    Last Post: 01-14-2006, 12:22 AM
  5. Where to get metric bearings for ballscrew?
    By gentoo in forum DIY CNC Router Table Machines
    Last Post: 12-22-2004, 09:00 PM
