585,573 active members*
3,498 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Correct Stepper Motor Driver Board Switch Settings
    Dec 2013
    17
    I was wondering if someone might be able to assist me in deciphering what the switches on my Stepper Motor Driver Board do.
    Here is a link to the manual for the driver board:
    LINK: http://blog.pennybuying.com/down/a/A931A.pdf
    ... and here is a link to the specs of the stepper I would be using it with. The motors came with my Zen Toolworks CNC mill:
    LINK: Nema 23 Stepping Motor - Zen_Toolworks_Wiki
    Any help would be appreciated. Thank you so much!!!
    Dec 2006
    13
    ok the 3 silver switches labeled sw1,sw2,sw3 select the amount of amps you want to run the steppers at. the legend is the upper right table labled "Current Settings" 0 represents off, and 1 represents on. there fore if you want 1amp sw1 and sw2 will be off and sw3 is on.
    on the red switch number 1 and 2 select your torque setting. 100% torque is both 1 and 2 on.
    3 and 4 select the microstep mode or "excitation mode". 1/8 microstep is 3 and 4 off.
    5 and 6 select the decay mode. 0% Decay is 5 and 6 on.
    on the zentoolworks breakout board "com" goes to the "+5v", "step to pul-" and "dir to dir-" on your driver
    Dec 2013
    17
    Excellent! Thanks for the reply. That's starting to make sense now, with it explained that way.
    I'm pretty new to CNC altogether, but since I switched from using my parallel port (which I originally purchased through Zen) to now using USB, I have been soooo much happier. Now that I know what the settings are for this board, I think I would probably buy another one just like it. I really dig the controls, and the software has been a ton easier to learn too (in comparison to Mach 3). Thanks again for the reply!!!
  1. CNC stepper motor driver board TB6560
    By Chaparro1973 in forum Spanish
    Last Post: 12-27-2011, 07:00 PM
  2. 6 leads stepper motor connect to TB6560AHQ stepper driver board
    By wf1318 in forum Stepper Motors / Drives
    Last Post: 07-25-2010, 08:19 AM
  3. Stepper motor A vs driver board A
    By tsknutsen in forum Stepper Motors / Drives
    Last Post: 03-14-2009, 02:41 AM
  4. Need help to locate stepper motor control board plus driver
    By Techbuilder in forum DeskCNC Controller Board
    Last Post: 10-14-2008, 01:11 PM
  5. Stepper Driver, Controller, Breakout board, Home switch, ?????
    By perolalars in forum CNC Machine Related Electronics
    Last Post: 10-28-2007, 03:35 PM
