Most all of us quickly discovered that the original equipment chip deflector panel is a joke. It's a pain to slide the panel into the slots and chips and coolant easily fly over the top.
There's been a lot of clever solutions posted here -- various enclosure designs with doors, curtains, etc. For the less ambitious I have an easier solution: the pictures attached explain better than a lot of words. The lexan panel is weighted by a piece of aluminum tube that I happened to have at hand. When I need to change parts or tools, I just flip it up to one side or the other where it can drain back into the enclosure. Flipping the panel to the side is quick and easy.
I have been using this arrangement in production for more than a year and have found it to be 100% effective. Putting the panel closer to the action means that a smaller panel covers a larger solid angle of spray. And if you are wondering... no, there is no spray that goes under the panel and gets out. If I were doing it over, I'd probably make it just a little narrower to the left and right: maybe 26" wide by 10" tall.
Attachment 213874
Attachment 213876
