Hi all,
I've been going back and forth on Build CNC or Buy CNC and initially I started out wanting to build, then I thought, well perhaps I should
buy a turn key like a Syil X4. Then I started thinking to myself "what if I get an X4 with all sorts of issues" I might as well just build my
own and learn in the process and understand what everything does, how it interfaces and how to repair it when it breaks.
So, I am back on the "build it" mind set and this is what I've come up with. I would like the seasoned veterans to check out the list and
let me know what you think. I am not concerned with saving money, so no need to say "Get this it's cheaper" but if something is truly
better, then I certainly want to know!
1 Grizzly G0619 X3 Mill $1894.00 (With Freight)
1 CNC4PC C32 - Dual Port Multifunction CNC Board $186.00
1 CNC4PC A61 Inductive Switch Assembly to RJ45 $78.00
1 CNC4PC USB Smooth Stepper Board $165.00
1 CNC4PC MPG4 - 6 Axis Pendant $180.00
1 CNC4PC 3-Axis NEMA23 CNC Kit (48V/12.5A/570 oz-in/5056D) for SIEG X3 $701.95
1 CNC Fusion Deluxe Ball Screw Kit $969.00
2 CPL-EKL-16-0.125 Zero Backlash Couplers $80.00
This doesn't include the controller PC, or the CNC Enclosure, I'm not sure what I want to do for an enclosure yet. I also want to integrate
an oiling solution (one shot) and a coolant solution as it's being built.
