585,727 active members*
4,008 visitors online*
Results 1 to 7 of 7
    Okuma Osp 5000L
    Hi Guys
    Wich program I can connect to an okuma osp5000L for DNC this machine?
    Feb 2009
    6028
    No DNC available for a 5000L, was a VERY special option on the 5020L. If your only wanting RS232 communications, anything will work. Lots of free ones available, even hyperterminal would work.
    Apr 2009
    1262
    I think Underthetire is right, full DNC ie; drip feed isn't available for that one...however if you just want to upload and download files, there are several easy and free methods as well as the more advanced (read $) methods. That machine control can communicate through it's RS-232 port.
    For example: eNETDNC Lt - eNETDNC
    Best regards,
    Thanks Dear Okumawiz
    can i do with Cimco?
    if yes,with how much baud rate or .... ????
    Apr 2009
    1262
    Should be able to do it with most communication software. Typically run 9600,7,E,2. Not had much luck at higher speeds with any distance.
    Best regards,
    Feb 2009
    6028
    an early 5000l might not communicate above 1200 baud, and requires hardwire handshake. a 5000lg would do 9600.
    Sent from my Quantum using Tapatalk
    Thanks all
  1. Okuma LB15 OSP 5000L
    By CNCAndy in forum Mastercam
    Last Post: 01-23-2022, 08:09 PM
  2. Okuma LB15 with 5000L error message
    By stude8 in forum Okuma
    Last Post: 07-25-2019, 02:48 PM
  3. Replies: 3
    Last Post: 09-25-2015, 01:52 AM
  4. Okuma OSP 5000L M19 Code
    By devangrathod in forum G-Code Programing
    Last Post: 05-12-2012, 07:53 AM
  5. v22 won't post correctly to Okuma OSP 5000L
    By NJC in forum BobCad-Cam
    Last Post: 12-21-2008, 03:16 PM
