I have built a CNC 4-axis foam cutting (hot wire) and the fine tuning is well under way. I run into a big resonance problem. I run the machine at a very low speed, and the motors resonate so hard the whole machine vibrates. The vibrations even cause the foam to move about on the table when I move the wire at cutting speed outside the foam. The problem is gone when I increase the speed, but to cut the lower speed and lower amp setting on the wire give the best results. So, I need to reduce / get rid of the resonance.
I am thinking about increasing the microstep settings on the controllers, and change the steps / millimeter setting in the software. Would this make a change, are there any other suggestions worth trying? I would not like making a belt drive between the motors and the spindles to increase motor speed at the same spindle speed.
Cheers,
Hugo
