585,996 active members*
4,940 visitors online*
    Nov 2011
    Circle Problem
    Dear All
    I'm using Artcam, and Planet USB MK2/4 controller, export file as Gerber ISO, when i cut rectangle or curve everything smooth and well, but when i cut circle i face problem that its not circle!!, I attached the NC code, also attached image for cutted circle in blue color, and what it must be in black color.
    anyone know what is the problem, appreciating your help.
    Aug 2013
    10
    I've imported the gcode you provided back into ArtCAM using the ArtRead function and it seems to look fine.Attachment 216740Attachment 216742
    I would look in the controller settings...
    Have a great day - Adam
    http://www.reliefs3d.com/
    Oct 2012
    87
    Circle Problem
    Looks strangely like a backlash compensation.
    Alan
  1. Circle cut problem
    By eragon9876789 in forum Mach Mill
    Last Post: 01-16-2013, 01:32 AM
  2. Arc and Circle problem
    By blacksmithjim in forum Uncategorised CAD Discussion
    Last Post: 08-11-2012, 01:50 AM
  3. Milling circle problem
    By bman356 in forum G-Code Programing
    Last Post: 02-26-2010, 07:19 PM
  4. Circle problem
    By Captain Midnigh in forum Milltronics
    Last Post: 11-09-2006, 09:11 PM
  5. Circle is it problem
    By bunalmis in forum Gecko Drives
    Last Post: 01-15-2004, 01:15 AM
