Hi All,
I've recently become the proud owner of a Sieg SX3, I've now been through the whole process of disassembling, cleaning and reassembling, and now have a working machine. While I was at it, I decided it would be a good idea to measure and model the machine to help with future modifications, and thought I'd share it with you all.
Below are links to IGES, STEP and ProEngineer versions of the model, I'd recommend the IGES (or ProEngineer if you're running WF5 or Creo onwards), make sure you untick 'Download using download accelerator' on the download page...
IGES - Download sx3 iges zip
STEP - Download sx3 step zip
ProEngineer (WF5/Creo) - Download sx3 asm zip
I should note that I can't guarantee the accuracy of this model, machines no doubt vary due to tolerances and design changes, I've also fudged some bits to make them line up. I didn't bother breaking everything down to individual components (largely because I was getting fed up after 1.5 days of modelling), and I've not included any of the fixings. Therefore, make sure you verify all dimensions if you're using it to design any modifications.
Hope that's of use to some of you, let me know if there's any glaring errors or if the links go dead.
