585,967 active members*
4,116 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Screen Layouts, Post Processors & Misc > possible? usb numeric key pad as a low tech stand-in for a cnc router pendant control
    Mar 2012
    27
    Question possible? usb numeric key pad as a low tech stand-in for a cnc router pendant control
    I'd like to know if a simple remote usb numeric key pad can be used as an unsophisticated but functional manual x-y-z movement controller for my Mach3 based Gantry Router. I've done some preliminary searching and found no information so I thought I'd throw the question out there hoping for some helpful input. Don't really want to spend much money and the capabilities needed are basically those found using the typical keyboard numeric pad. Does this work? Is it complicated to set up? Any experiences or direction would be much appreciated.
    Yes, a USB keypad works on my milling machine with Mach3.
    I have to be careful about positioning of my keypad though because it's quite sensitive to electro-magnetic interference and behaves unpredictably if it's too close to the VFD or motor wiring,
    Regards,
    Nick
  1. Replies: 1
    Last Post: 01-20-2014, 06:24 AM
  2. DNC direct numeric control
    By AMTB in forum DNC Problems and Solutions
    Last Post: 04-21-2012, 07:12 PM
  3. DNC direct numeric control
    By AMTB in forum CNC (Mill / Lathe) Control Software (NC)
  4. stand alone pendant....help
    By the4thseal in forum Controller & Computer Solutions
    Last Post: 06-10-2009, 10:15 PM
  5. Numeric Pad Pendant Setup??
    By bigz1 in forum Mach Wizards, Macros, & Addons
    Last Post: 10-29-2008, 06:18 AM
