585,733 active members*
4,937 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Polls > What NEMA motor size are you using
View Poll Results: Which Motor Standard Are You Using In Your DIY Router?
Voters
319. You may not vote on this poll
  • NEMA 17
    12 3.76%
  • NEMA 23
    168 52.66%
  • NEMA 34
    91 28.53%
  • NEMA 42
    18 5.64%
  • Have not choosen yet!
    43 13.48%
  • None of the above
    7 2.19%
Multiple Choice Poll.
Results 1 to 18 of 18
    Cool What NEMA motor size are you using
    What NEMA motor size are you using in your CNC home made router project?
    NEMA 17
    NEMA 23
    NEMA 34
    NEMA 42
    Have not choosen Yet!
    None of the above
    www.widgitmaster.com
    It's not what you take away, it's what you are left with that counts!
    May 2006
    249
    Quote Originally Posted by widgitmaster
    NEMA 17
    NEMA 23
    NEMA 34
    NEMA 42
    None of the above
    I will be using NEMA 23 mounts...Taig mini-mill paired with a 4-axis servo setup from IMService.
    Edit- Whoops, saw they were for a router...Never mind, then! Sorry!
    May 2006
    24
    nema 23
    Jun 2003
    866
    on my bridgeport series II, 42 and hopefully 34
    I have some Nema 34 and Nema 23 that I hope to use on a router. Nema 34 brushless servos should be big enough for a very fast router. For that matter, I have a set of Nema 23 motors that probably would be scary fast on a router.
    Aug 2003
    494
    I am using NEMA 17 for the XZ and NEMA 23 for the Y axis. Nema 17 at 24 volt and 1.2A and belt drive and they are more powerful than first imagined. I will use some more for another router project at a later date
    I am not completely useless.......I can always serve as a BAD example.
    Nov 2005
    938
    I actually now have 2 complete sets. a set of 3 Nema 23, 425 in oz motors and a set of 5 nema 34 625 in-oz. I'll use the larger ones on my machine and the smaller ones on the girlfriends machine.
    If you cut it to small you can always nail another piece on the end, but if you cut it to big... then what the hell you gonna do?
    Steven
    Dec 2005
    21
    I have ema 23's on both my Taig mill and Sherline lathe. I plan on using 23's on a CNC router I am building.
    Cheers
    PiperTom
    Aug 2005
    1622
    The motor frame may be of some interest, but Oz. In. or torq spec and the source to drive them would be another spec pair to pay close attention to. Parallel vs series connected for at least bipolar types plays a large part on the torque curve capacity and current demands too.
    My Compumotor Nema 34's only have 200-400 Oz. In.'s to do the job driven with S6 or Zeta4 drives. There are much higher output motors available, but obvious drives must match that demand even though a 34 frame. Since 6 amps is max on the S6 drive, the higher torque motors would starve with these limitations.
    Something is going to suffer.....usually it's connected to your wallet?
    DC
    Nov 2006
    i'm using NEMA 23 on my sherline with a Xylotex 3 axis board.
    The HobbyCNC 200oz/in motors. I dont know what they are.
    Oct 2007
    16
    nema 23's with a soc-machines 4 axis controller
    Rob C
    Mechanical Designer/ Welder Fabricator.
    Jul 2003
    114
    Smile
    Nema 34 with Gecko 210 on my diy 25 x 39 and Nema 23 with xylotex 3 axis on my midi-router
    Aug 2005
    191
    I'm running Nema 34 Slo-Syn surplus motors from disc drives because they were cheap. 5 steppers off Ebay for 42.50 plus shipping. I'm running them at 20X the rated 1.7V with a 4 axis Hobbycnc board.
    Dec 2006
    13
    I own a Practical CNC equipped with Servos. I can not identifiy the make or size on the 6 x10 mill. I call PCNC. Their tech team is worthless. Any ideas on how to identify what this machine has?
    Your thoughts are appreciated.
    FFAMN
    Dec 2003
    24220
    Quote Originally Posted by FFAMN View Post
    FFAMN
    The Poll did not specify stepper or servo?
    NEMA size is not in itself an indication of torque, just frame size.
    Al.
    Albert E.
    Feb 2004
    361
    23's on the old MDF router, 34's on the plasma table, and a shoe box full of servo's for gps steering ....
    Apr 2014
    432
    Re: What NEMA motor size are you using
    34's with vampires these geko's are the ducks nuts.
    Dec 2003
    24220
    No idea why this poll is still running!
    There appear to be some that somehow think that NEMA mount is related to a torque value, where in fact it can vary depending on the motor construction, particularly steppers where the length/torque can vary in a wide margin, for the same NEMA mount!
    Al.
    Albert E.
  1. Nema 17 Stepper motor on Nema 23 driver
    By Thomas T in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-21-2014, 08:59 AM
  2. Nema motor size?
    By hanau in forum Benchtop Machines
    Last Post: 11-12-2013, 06:21 AM
  3. Pulling my hair out trying to identify NEMA motor size
    By drboostv6 in forum Stepper Motors / Drives
    Last Post: 11-06-2011, 11:40 PM
  4. NEMA frame size
    By RP Designs in forum Servo Motors / Drives
    Last Post: 11-16-2009, 08:31 PM
  5. Hopeless newbie needs help with NEMA size
    By glw in forum Stepper Motors / Drives
    Last Post: 10-27-2006, 12:50 AM
