584,863 active members*
4,933 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > VFD controlled by Mach3. Need to lower my 0-10VDC to bring the actual speed to the...
    Oct 2005
    278
    Question VFD controlled by Mach3. Need to lower my 0-10VDC to bring the actual speed to the...
    VFD controlled by Mach3. I Need to lower my 0-10VDC to bring the actual speed (requested in mach3) to the speed that I actually get (as shown by my Index Pulse card)
    Its all working, by I cannot lower my voltage enough either on my CNC4pC board or my dedicated 12vdc PS to "tune" the spindle (actually RPMs) to the RPM's I request.
    Can I just put a resistor on the PS output? or on the 0-10VDC output on my CNC4pC card? if so, what value would I try to get an approximate 20-25% reduction in voltage output?
    Nate.
    Nate.
    Ann Arbor Meechigan
    You need a voltage divider. You can use a 10k potentiometer (check the manual to see how much input impedance is recommended) with the input tied to one fixed side and the other fixed side tied to GND. Tie the adjustable pin to the input of your VFD.
    Jan 2013
    119
    Why not make the adjustments in Mach3 > ports and pins>spindle settings >
    pulley ratios?
    By adjusting the low and the high speed settings ,better calibration
    should be attainable. Also there should be a setting for pulse count
    from the index pulse card.
    Mike
    Jan 2013
    119
    Thinking more about this your problem is that you do
    not have software settings matching the hardware.
    The number you have set for max speed in pulley ratio settings does not
    match the spindle motor's full speed rpm.
    First establish what is the full rpm of the spindle motor.
    In ports and pins> spindle setup, set up a pulley ratio of ( 0 - 100)
    Start spindle and run with S100 . rpm showed is the max rpm
    of your spindle motor. The S100 sets the pwm signal at 100 percent.
    Take that number and set up a pulley ratio.
    This should get you up and working.
    Mike
  1. Actual rapid speed Mori NT 1000?
    By Tolyatti in forum Mori Seiki lathes
    Last Post: 08-06-2013, 12:23 AM
  2. Replies: 0
    Last Post: 06-11-2010, 07:59 AM
  3. Replies: 4
    Last Post: 08-11-2009, 10:31 AM
  4. 92' 88HS - actual feed/speed display?
    By esolatimore in forum Fadal
    Last Post: 03-26-2009, 01:21 PM
  5. cnc controlled mandrel bender controlled by mach3
    By timmyb199 in forum Bending, Forging, Extrusion...
    Last Post: 05-31-2007, 12:35 AM
