585,567 active members*
3,345 visitors online*
    Dec 2013
    Coolant laser tube?
    I have Kaitian CO2 laser, 60W tube, and it's at a place which I can't warm every day, and the temperature can go UNDER -10 Celsius degrees (10 F) sometimes. Can I use antifreeze for cars? Do I really need to use destilled water and why? And, one more thing - how much is optimum operating temperature range for coolant?
    Greetings!
    Nov 2008
    644
    Re: Coolant laser tube?
    I use RV antifreeze. It's a non toxic antifreeze used to replace the water in lines of trailers and houses that have no heat when not used. I circulate this fluid while the container sits in ice water. I'm targeting between 10 and 20 Deg C. I'm using a PC pump with a decent flow. I ales use a radiator that sits in the ice water. Cooling like this is inexpensive but necessary
    May 2015
    13
    Do you use the RV antifreeze only, or mix with water? If mixed what sort of ratio?
    Thank you for your time and assistance.
  1. Replies: 0
    Last Post: 06-21-2014, 07:12 AM
  2. Replies: 0
    Last Post: 06-11-2014, 10:10 AM
  3. Reusable CO2 100W 130W 150W Laser Tube ? Replace the traditional CO2 laser tube
    By dianmanlaser in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-03-2013, 05:04 AM
  4. I changed from synrad rf laser tube to glass tube and it is not working good
    By david Neumann in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-15-2012, 03:22 AM
