585,973 active members*
4,145 visitors online*
    cutting wrong size hole
    New at this, having a problem cutting a 2" hole, the hole comes out to be 2.125" instead. My cutting bit diameter is .125. Is there somewhere in lazycam or mach3 that needs to know to cut inside to circle?
    Jul 2003
    92
    Re: cutting wrong size hole
    You have to subtract your bit size form the hole you draw, if you're using the free version of LazyCam that came with your Mach3. Only the Pro version of LazyCam can automatically offset to accommodate the bit width. Hope that helps.
  1. My parts are coming out the wrong size!
    By bremerr in forum DIY CNC Router Table Machines
    Last Post: 12-18-2015, 04:43 PM
  2. G540 cutting size wrong
    By Ed Williams in forum Gecko Drives
    Last Post: 10-30-2011, 01:53 AM
  3. Wrong Ballscrew Size?
    By ozzie34231 in forum Linear and Rotary Motion
    Last Post: 01-04-2008, 06:23 PM
  4. Purchased aluminum, sent wrong size, too big, now what?
    By pzzamakr1980 in forum MetalWork Discussion
    Last Post: 09-20-2007, 03:54 PM
