584,846 active members*
4,180 visitors online*
IndustryArena Forum > CAM Software > FeatureCAM CAD/CAM > stl`s and 5 axis programming
    Jul 2011
    218
    how can I make surfaces from an stl?
    also the stl is a part I need to do in 5 axis but ive only ever done 4 and ive got no idea
    can someone help me understand 5 axis programming using 2012
    CHOCLATE? THIS IS DOODOO BABY!
    Aug 2013
    10
    There is no easy way of turning stl's into Iges surfaces. That said there are workarounds:
    All of the Delcam software recognise stl as geometry for machining, you just have to set it up properly.
    Obviously it's easiest in powermill where stl's are just another piece of geometry to machine.
    In FeatureCAM you have to set it up before machining.
    I think you should get in touch with your reseller for him to tell you how to do that.
    Anyway the easiest way I found to work with 5 Axis Stl's was always PowerMILL - It's a software that cuts through them like butter
    Check it out
    Adam
    Have a great day - Adam
    http://www.reliefs3d.com/
  1. 4 Axis Programming with BobCAD V25 4 Axis Pro
    By aldepoalo in forum BobCad-Cam
    Last Post: 07-30-2013, 08:52 PM
  2. Need help with 4-axis programming
    By Adaware in forum Mastercam
    Last Post: 02-23-2009, 11:26 PM
  3. 3 Axis CNC programming.
    By cncneo1 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-06-2007, 06:46 PM
  4. 4-axis, 3+2, or 4+ axis programming system?
    By roboticist in forum Uncategorised CAM Discussion
    Last Post: 09-04-2006, 07:02 PM
  5. 4 and 5 axis programming
    By Cammotion in forum G-Code Programing
    Last Post: 03-03-2005, 06:39 AM
