585,754 active members*
3,857 visitors online*
IndustryArena Forum > CAM Software > ArtCam Pro > multicam 5000 series issue with artcam file transfer
Results 1 to 6 of 6
    Jan 2007
    91
    we have a small issue with router.
    we have been machining file on router using enroute software.
    recently we have a 3d wood carving job , and would like to send the 3d files directly from artcam.
    when we send sizes getiing smaller, for example if i send a circle of 20 cm it cuts only 7.6 cm dia circle.
    can anyone fix our issue, hoping your advice soon.
    Aug 2013
    10
    What postprocessor are you using? are you programming (modelling) in inches or mm? Is the postprocessor in inches or mm? are the tool definitions correct (diameter and geometry)?
    Have a great day - Adam
    http://www.reliefs3d.com/
    Jan 2007
    91
    Re: multicam 5000 series issue with artcam file transfer
    Quote Originally Posted by Reliefs3D View Post
    multicam plt mm.
    artcam modelling using mm
    postprocessor in mm
    yes tool dia and everything is fine
    Dec 2011
    59
    what version and build are you using ?
    is it the downloaded demo version or have you purchased a license?
    Gary
    Beckwith Decor Products
    ArtCam Reseller/Trainer, Custom tooling & Onsrud Dealer
    Jan 2007
    1795
    call delcam support
    1-877-335-2261
    we had issue with multicam, and they solved in minutes..
    little weird why youre using plt files? uise gcode and everything will be correct..
    there must be multicam postprocessor.. tough what I know multicam using only inches...
    mightbe im wrong..
    why is enroute involved anyway? its very confusing..
    you can use either way enroute or artcam.. when you sending around between files... it can happen within conversions tolerance issues
    imagine if you were using meter, then 2 digit only shows centmeter precision, while using mm same 2 digit precision shows thoushd of one millimeter...
    Jul 2008
    4
    20/2.54 = 7.874
  1. Servo Drive - MULTICAM 5000 Series.
    By Routerfiend in forum Servo Motors / Drives
    Last Post: 01-22-2014, 09:55 AM
  2. Multicam 5000 Series - Fail to initialize
    By frans in forum Multicam Machines
    Last Post: 07-22-2013, 06:12 PM
  3. Multicam 5000 plunge issue
    By RodneyPierce in forum Multicam Machines
    Last Post: 06-07-2012, 08:44 PM
  4. Multicam 3000 Series vs AXYZ 5000 Series
    By adamfilip in forum Commercial CNC Wood Routers
    Last Post: 10-18-2010, 08:54 AM
  5. NEED HELP - MULTICAM 5000 SERIES
    By loyedp in forum Commercial CNC Wood Routers
    Last Post: 09-21-2010, 04:08 PM
