The machine can be running just fine, then all of a sudden it throws a limit switch error. None of the axis are no where near a over travel switch. I tried running the machine and watching the diagnostics screen. Watching the over travel lights to see which axis was giving me the error. 2 times it gave the error while I was watching. None of the limit switches lite up. I did notice while it was running the output #1 light kept blinking. Is that normal, or could that be what is causing the problem?
MACH3
G0704 using stock screws.
KL-6050 stepper motor drivers
C-10 parrallel break out board
KL 600-48 48VDC/12.5A Switching CNC Power Supply
nema 23 570 oz (KL23H2100-50-8B)
Micro limit switches (Micro Limit switch | Automation Technology Inc)
David Branch
