585,602 active members*
3,614 visitors online*
Results 1 to 13 of 13
    Jan 2014
    5
    Bridgeport Interact 720
    New to this site. my company has bought a Bridgeport interact 720 with a Heidenhain TNC 151 controller. When we power up the machine it goes through a memory check and the says power interruption I clear that but get a fault ( axis 4 meas. system defective a ) this is a 3 axis machine how wiil be able to clear this fault. Thanks.
    Jan 2014
    5
    After doing some checking the controller is actually a Heidenhaim 351 B.
    Nov 2004
    3028
    Try a PM to Gus. he has a bunch of these machines.
    I know that under the MOD key is where you can turn the 4th On or OFF, select display size, type of communications, access parameters etc.
    But I need to be in front of a machine and write down what I do instinctively.
    George
    Jan 2014
    5
    Thanks George
    1121
    I think you have a parameter mis set needs to have 4th axis disabled
    Jan 2014
    5
    That's what we are thinking. Just found out they the company we bought this from was using a rotary table so the 4Th axis was in use. We are trying to locate a parameter list for this machine also a programing manual for the controller. Can't seem to find how to get into the main parameters.
    Jun 2011
    61
    Re: Bridgeport Interact 720
    Hi Monte , did you get an answer to your problem ? Im looking for the parameters toi put in my Heidehain to use the 4th axis ! Any help would be great , thank you Harry
    Jun 2011
    61
    Hi Gus , I hope you can help me , Im looking for the parameter to install the 4th axis ,can you help ? I hope so , thank you Harry
    1121
    code 95148
    just like all the controls
    there are manuals on the heidenhain website that should tell you which parameters are which
    Jan 2014
    5
    Thanks very much Gus
    Apr 2005
    37
    After the machine has powered up-
    press the MOD key and cursor up to "user parameters"
    Press enter-
    cursor up to "XYZ=0 XYZB=8"
    Press "0" to turn off the forth axis
    Press enter
    Press "end block"
    Jun 2011
    61
    Quote Originally Posted by Daninwyoming View Post
    Press enter-
    Press enter
    Press "end block"
    And the other way round what do I do to get the 4th axis on my Interact please ? Hope you can help
    May 2004
    402
    DELETED
    other had answered
    Andrew Mawson
    East Sussex, UK
  1. Bridgeport Interact 412
    By Gncc50 in forum Bridgeport / Hardinge Mills
    Last Post: 07-22-2019, 04:32 AM
  2. bridgeport interact 520
    By goodmancncgcode in forum Bridgeport / Hardinge Mills
    Last Post: 04-03-2013, 02:53 AM
  3. Bridgeport Interact 1 MK 2
    By tommo61 in forum Bridgeport / Hardinge Mills
    Last Post: 12-23-2011, 04:34 PM
  4. Bridgeport interact 412
    By la1508 in forum Want To Buy...Need help!
    Last Post: 07-09-2010, 10:52 PM
  5. Interact 308 Bridgeport ?/:????
    By SGARCIAM in forum Bridgeport / Hardinge Mills
    Last Post: 08-21-2008, 10:22 PM
