I have a surplus of these Truck Sensors around and was curious if they could be wired to a BOB. Not really sure on there data.
Attachment 217194
Attachment 217194
Link does not work, what is the model No?
Al.
Albert E.
Those are 2 wire N.O. AC/DC type, so they should work on any input from +10vdc and up.
Polarity should not matter.
Al.
Albert E.
So the third wire (green) is just ground or is it used for power?
Thanks for the help.
Earth Ground, not power ground (common).
Al.
Albert E.
Ok. Thanks I will give them a try.
