I am very new to this Can anyone tell me the right way to wire a bl-mach-v1.1 d304 breakout board to a HY-DIV168n- 3.5A driver.
I don't have that combination of equipment, so this is just a guess.
You could try connecting (for the X axis):
XS to PUL+
XD to DIR+
XE to EN+
and
XN to PUL-, DIR-, EN-
Thank you for your advice' but it stall is not working I will try diff setting .
What exactly is happening?
Are you getting "holding torque" on the motor? Is there any response when you try to jog the motor in one direction or the other?
Do you have a USB cable plugged in to the breakout board (or other source of +5 volts)?
You might try removing the connection from XE to EN+ (some drivers are enabled by default).
thank you doorknob your post of XS to PUL+
XD to DIR+
XE to EN+
and
was good the problem was in the software settings I missed the Enable1 pin active low set.
All motors are run now'
Glad to hear that you've gotten things working.
