Hello, all -
I have a pretty mongrelized setup at this point. It started life as a Vision 2448 combo router / engraver with dual heads and a Series II serial controller. I've pretty well hacked things apart at this point - I've removed the second head (I only need one for most of what I'll do) and I've bypassed the control functions of the controller, using it for nothing more than a power supply - I feed the drive boards (Intelligent Motion IM483's) from Mach3 and an extra parallel port with added +5V from a USB port. I've replaced the engraving spindle with a Bosch Colt.
Now we get to the problems.
1. The X/Y stepper motors appear to be NEMA 34's. The mounting faces are approximately 3 7/16 square, BUT they don't have any data plates or markings. The current limiting resistor on the driver boards has them locked down to 2.6A. This may or may not be even close to the real amperage rating though, because the Z/A boards are set to ~1.9A, and the actual Z steppers - which do have data plates - are rated at 2.3A.
2. I'm losing zero while cutting. Let's say I'm doing a simple profiling operation. I'm cutting out a piece of ~6" x 9" UHMW. (This is based on reality this past weekend.) I've got the cuts set at 100 ipm, .0625"/pass. (When jogging, I can move - usually, but we'll get to that later - the head at 200+ ipm, and there's no bogging down on the spindle when cutting at 100.) The first few passes will be perfect, but the next pass ... the zero seems to have shifted by 3/16 or 1/4 or so, in a seemingly random direction. No idea why. This also happens while jogging from time to time - I can set zero, then jog around some, then tell Mach3 to send my head back to zero ... and I'm off.
3. Stalling. In general, everything moves as expected ... but now and then, the steppers will start to stall, seemingly randomly. They will continue stalling - while still moving the head - until I kill power to the drivers / steppers and then turn it back on again. After this, they'll run for a bit longer without any stalling - anywhere from 1 to 15 minutes or so - but then they'll make that stalling sound again, and nothing is accurate until I kill power and start it again.
Anyone have any ideas?
It's been put to me that the power supply might be inadequate, but this doesn't really make any sense as I'm still using the exact same power supply setup that the machine shipped with from the factory. The only thing I've really changed is that I'm feeding the step/dir and opto power from a different source (LPT1 & USB, respectively). The transformer appears to be an Avel Lindberg D4040, which looks to have 2x 25V/4.6A outputs. This seems a little low ... but 2x 2.6A + 2x1.9A seems to add up to about the same as 2x4.6A.
I'm pretty much lost, here. Help?
