584,841 active members*
4,264 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Help with operations: milling one surface
    Mar 2013
    82
    I'm reasonably new to CNC. Have had no issues with setting up operations etc until now. Here's a picture showing simply the stock and in blue the surface I want to mill. When I do a 3d milling operation it happily cuts away at the circle first but then does the outside of the stock. Normally that would be fine but this time for s & g's I only want to mill this one face. I've tried every process I can think of as well as redefining the geometry in solidcam but it won't allow me to do that one surface.
    Am I missing the big picture? Is there something I should have done during the cad process to make this easier?
    Many thanks for any help
    Raf
    Mar 2013
    82
    Sorry image didn't load.
    Attachment 217456
    Apr 2009
    5516
    Quote Originally Posted by Raf-1200 View Post
    Attachment 217456
    Did you try creating a boundary around the area?
    Another way would be to extract the curve, create a parallel curve 1/2 the cutter width away, then use a profile toolpath.
    Mar 2013
    82
    Yes I tried creating a boundary but it didn't help. I think it's something to do with the 'geometry ' settings in Solidcam but I still haven't worked out how to manipulate it. Your second idea is a good one too. If I can't figure it out soon I'll do that. Thanks
    Www.mostynindustries.com.au
    Cafe Racer and Custom Bike Builds
  1. 3D Surface Toolpath milling deeper than surface
    By moto1965 in forum Mastercam
    Last Post: 07-30-2014, 04:15 PM
  2. Multiple milling operations
    By swarfzone in forum PTC Pro/Manufacture
    Last Post: 03-22-2012, 02:11 PM
  3. Losing tram during milling operations?
    By noobCNC in forum Uncategorised MetalWorking Machines
    Last Post: 11-01-2011, 08:22 AM
  4. copying surface roughing operations
    By chuy in forum Mastercam
    Last Post: 01-11-2008, 05:46 AM
  5. Surface Milling
    By camtd in forum EdgeCam
    Last Post: 10-20-2006, 06:08 AM
