Have a new problem on my BMC 20. After powering on, I get the flashing block cursor on screen and then, "Servo Amp Fault On Z Axis". This appears before the, "** Machine Configuration **", appears on the display. I cannot clear the fault.
It has been much colder than normal here the last week and I have tried putting a small space heaters in the electric cabinets in the back for a little while to help warm them up. I've also tried swapping the ribbon cables between the Y and Z in the right-hand cabinet (error stayed the same, Servo Amp Fault On Z). I've looked for any tripped breaker in the cabinets and cannot see any, but maybe I have missed one or more.
After initial problems and resolutions for Y-axis and toolchanger issues, the machine had been powering up properly and I had been able to run warm up cycles and short programs to test it out.
What are the steps to logically troubleshoot the Z Amp Fault?
