Hi Folks,
I have a 6040 machine with black box from YooCNC, no major changes on it as all seems to work OK for Wood. I did not try to machine Aluminum yet but I intended to do some small metal work and have coolant system / atomizer (Sommer ZN) installed.
Now I would like to manufacture Heated Print Bed for 3D Printer, the part would have following specs:
* 230x230mm size, T6082 Aluminum, raw sheet is 250x250mm
* Level surface, I plan to take off ~1/3mm from each side for that.
* 200x200x2mm pockets on both sides, pockets can have round corners.
Big question is: This is a big part, much bigger then pieces I initially thought to do. Will my 6040 be able to perform the task with reasonable quality?
If yes, what about tooling? What would be the optimal mill type, diameter and coating for this kind of job?
Will this be a good choice: Maritool 3mm 3 Flute Carbide End Mill 38 Deg Helix 12mm loc ZrN?
Thanks!
