585,602 active members*
3,445 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > How to run chip belt on Okuma LCS15 + OSP700?
Results 1 to 6 of 6
    Nov 2011
    21
    Hello guys. I am from Israel.
    No Okuma agency in my country.
    I learned by course for OSP 5020(hopefully found with google) by my self, and have no idea where to ask this question.
    No button on OSP700 of chip belt like on fanucs.
    Nothing found in okuma lathe code listing.
    How can I run chip conveyor?
    Thank you in advance.
    Apr 2009
    1262
    Okumas typically do not have control by M-code on a lathe or parameter except by special option. Just use the pushbuttons on the conveyor itself. If that doesn't do it for you, it is possible to add a timed relay and an Auto/Manual switch to the existing control box. This will help with forgetting to turn it on and also help reduce coolant usages and wear & tear.
    Best regards,
    Mar 2009
    1982
    M code, sample could be explained in "Special functions manual".
    Can You read the control specification table? Is the OSP Data Management Card paper in the door of main control cabinet?
    It depends generally, how the conveyor is connected to the machine. If there is solid multi - pin connector (could be "Honda") or two, that means, control is talking to conveyor. There is just an appendix, if connection is just 3F power supply. There can be variations for CE mark: Emergency Stop up to four lines, interlock up to four lines and so on.
    Feb 2009
    6028
    No mcodes. Simple on/off button.
    Aug 2011
    2517
    there's some buttons on the chip conveyor.
    see pic attached.....
    Nov 2011
    21
    I found Okuma partner in Israel, very accidentally the master told me by phone to seek buttons behind the lathe, unfortunately we placed machine too much close to wall.
    Many thanks for all you guys.
  1. Okuma Cadet OSP700 alarm 1055-20
    By b1apt in forum Okuma
    Last Post: 05-29-2022, 02:15 PM
  2. Okuma LT300 X-axis belt breakage
    By MIKEL12 in forum Okuma
    Last Post: 08-26-2016, 10:19 PM
  3. Replies: 3
    Last Post: 04-15-2013, 05:56 PM
  4. Where to get chip conveyor belt material?
    By SRT Mike in forum Uncategorised MetalWorking Machines
    Last Post: 10-20-2006, 10:37 PM
