585,567 active members*
3,446 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > How to Connect Relays to the KFlop Controller???
    Jul 2004
    235
    Greetings,
    Reading the info. on the website... it seems that the limit, for direct output, from the KFlop controller, is 3.3v @ 10ma. No add on cards.
    If so, could someone give me a little guidance or diagram, as to how I can control a bank of 24vdc relays.
    I do not want to buy the 32 I/O board, as my project must keep the cost way down.
    The relays I use are 24vdc 200mW coil, would that be 8.4ma??
    Does anyone make a board, that I could use to translate this to relay control. I can make my own board if needed.
    I am looking for 8 outputs, Kflop to relay control.
    __________________________________________________
    Also, for inputs, do I run neg. to my switches and back to the inputs,... or Positive out and back?
    Which is preferred?
    Sincerely,
    Jeff
    Robot & Machine Design - BLUECNC4, GreenCNC3, RedCNC2L, SilverCNC2; CNC Software!
    www.truemachinedesign.com - - - - - - - - - - - - - www.truemachineautomation.com
    24220
    If you want to wind your own, look at the ULN2803 relay driver, includes built in EMF diodes, use .2" spaced terminals in conjunction with Strip Boards Page half way down here Prototyping Boards
    You can also pick up Opto22 boards and the various I/O modules on ebay if you prefer.
    Al.
    Albert E.
    May 2006
    4045
    Hi Jeff,
    Winford.com sells a 4 channel relay board including relays for $55. They also show a circuit.
    Here is the circuit we use on our Konnect board.
    The DSS4240T-7 transistor used. High current gain (>100), up to 2A, 40V, low cost.
    The opto isolation may not be required for you. Just a 470 ohm resistor from the KFLOP output to the transistor base.
    Please make sure there is a reverse diode path across any relay coil to avoid the high voltage (spark) when the coil is switched off.
    HTH
    Regards
    TK
    http://dynomotion.com
  1. Kflop vs PlanetCNC USB motion controller
    By isvflorin in forum Dynomotion/Kflop/Kanalog
    Last Post: 08-21-2015, 07:03 PM
  2. KFlop controller to interface w/ Prototrak Servo amps
    By wonderdog5 in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-25-2014, 06:48 PM
  3. New MC with Fanuc Controller - Can I connect it to a wireless router?
    By SolidCAM_13 in forum Computers / Desktops / Networking
    Last Post: 06-25-2011, 10:31 AM
  4. Connect 2 steppers on one output on controller
    By ipo| in forum Controller Cards
    Last Post: 10-21-2010, 11:46 AM
  5. Need help to connect motor to controller
    By ezland00 in forum DIY CNC Router Table Machines
    Last Post: 11-16-2003, 06:08 PM
