585,753 active members*
4,559 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > how to connect single phase spindle motor with 3 phase inverter
Results 1 to 11 of 11
    Jun 2012
    11
    hello all,
    i have 2.2 kw 1 phase ac spindle motor which has to be driven by 3 phase vfd (inverter). can anyone please tell about the connections?
    also if i directly connect the motor with rated 220v 50hz supply, what may be the result?
    24220
    !ph motor cannot be driven from 3phase inverter.
    You need a 3ph motor.
    Is this a Capacitor start and cap run split phase motor?
    If it is a 220v rated motor, it should connect OK using 220v supply direct.
    What is the details on the motor plate?
    Al.
    Albert E.
    Jun 2012
    11
    thanx for reply,
    i have solved by following practice:
    i have used one of the three phases available from drive, now it rotates according to freq setting.
    the drive output is for delta connected motor, so i have to connect between any two phases, if it is star connection output(rarely found), i have to connect between any one phase and neutral.
    thanx again.
    if motor rotate in reverse direction, just change the phase selection say from u v w, use u-w or u-v pair the correct being decided by direction of motor rotation required.
    24220
    What make/model of VFD is this?
    Never heard of a 3ph and neutral output of a VFD?
    Al.
    Albert E.
    Jan 2013
    119
    Al
    This is interesting
    Mike
    Jan 2013
    119
    Al
    Sure would like to see the questions you asked. answered.
    Mike
    24220
    I would be interested as well!
    Al.
    Albert E.
    Jan 2007
    599
    in on this one, deff. need to know about this.
    Jan 2013
    119
    Al
    Its kind of Hard to imagine the amount of time and effort that you've put into
    sharing your insight over the last 10 years. ( 19,945 posts )
    Most of these posts you are sharing information ,and for very little in return.
    When you ask a question it's to gain more information, so a logical solution
    might be figured out.
    Maybe if you would have told him that that it would work,
    he would have posted the information that you requested.
    Keep up the good work.
    Mike
    24220
    Quote Originally Posted by Mzones View Post
    Mike
    Thanks, It does not look as though he comes here that often so it may take a while to find out, if ever?
    Al.
    Albert E.
    Jan 2013
    119
    I think you are right again!
    But I would like to see him PROVE that you are wrong!
    Mike
  1. Can I convert single phase motor to three phase?
    By Jim Estes in forum Phase Converters
    Last Post: 06-04-2020, 02:52 PM
  2. Convert three phase transformer to single phase?
    By jimjovan in forum CNC Machine Related Electronics
    Last Post: 09-16-2013, 11:32 PM
  3. Replies: 12
    Last Post: 10-13-2009, 03:53 AM
  4. 30 hp spindle motor on 240 single phase?
    By panaceabea in forum Phase Converters
    Last Post: 09-05-2008, 11:29 PM
  5. single phase spindle motor
    By Don Lester in forum Bridgeport / Hardinge Mills
    Last Post: 11-16-2007, 03:37 AM
