585,938 active members*
3,188 visitors online*
    Aug 2011
    27
    resetting a ST-28 MAZAK
    Hello. Anyone have the procedure for resetting a ST-28 MAZAK Lathe with Mazatrol T32 plus system. We did a reboot, after reboot the machine, automatic operation mode the program starts running, the tool moves, then the tool stops, the start button is pressed but does not obey, no alarm goes off. thanks
    Hi
    I just got a ST28N ATC MC from a tech school and your machine is very similar.
    How about keep contact?
    Eduardo- WhatsApp +5511966974533
    Jan 2013
    19
    Quote Originally Posted by edumarzolla View Post
    Hi
    If I can help you out I will.
  1. resetting a ST-28 MAZAK
    By emersonja in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-24-2014, 06:44 PM
  2. Resetting X0 Y0 Z0.
    By Witsenburg in forum Mach Software (ArtSoft software)
    Last Post: 06-05-2007, 03:39 PM
  3. Resetting the top view ?
    By altered in forum Mastercam
    Last Post: 03-17-2007, 10:03 PM
  4. Zero location resetting mid-run
    By esmiller in forum Machines running Mach Software
    Last Post: 03-03-2006, 09:00 PM
  5. resetting fields
    By hogman in forum GibbsCAM
    Last Post: 05-06-2005, 02:22 AM
