585,763 active members*
4,192 visitors online*
Results 1 to 11 of 11
    Mini Mill coolant presure
    Just bought a 2002 mini mill Awsome machine for the size.
    The coolant pump that it came with is the low low pressure pump. No blockage.
    I am thinking of upgrading to the high pressure pump but 1800 is a little steep.
    Is there a way of increasing the impeller pitch or does any one know of a cheaper pump to buy. looking for a programable coolant noosle also.
    Art
    Jul 2005
    12177
    Quote Originally Posted by engine tech art
    Art
    The standard pump runs on 240V and the circuit that supplies it can carry up to 10 amps. There is a breaker inside the cabinet labelled Coolant or something like that so you can check this. You could plug in any pump that runs off 240V or you could get a step down transformer and get a 120V pump.
    Regarding the programmable coolant nozzle you might be out of luck. Check the Haas website, Hasscnc.com to see if it can be retrofitted. I suspect the answer is no and even if it can the cost will be high.
    I find with a high volume pump you can run several nozzles spanning all your different tool lengths and get almost the same effect as a programmable nozzle.
    Thanks Geof I will look on Ebay or some surplus sites and try and find a punp.
    Art
    Whell looked around for a pump and nothing . Inspeced the pump and
    the impeller is tinny.So went ahead and made one same profile as stock but made the blades 2 time deeper and enlarged the inlet 20% and enlarged and radiused the outlet.
    If it would overload the moter and pop the breaker so then i would get the haas high
    presure pump. it works awsome twice the presure does what i want it to and no over load.Made the part with the MM for the MM.
    Art
    Art
    Jul 2005
    340
    anybody know what is inside a programmable coolant device ? anybody have photos ?
    Jun 2006
    had a high pressure pump burn out so installed a high pressure pump from a plumber friend, for water source, for around 500 and back in business again building high hp motors!
    Jul 2006
    22
    Billet racer we also build billet parts for motors. There the most power per cc out there.
    UBR
    billet racer what kind of mill do you have?
    Nov 2005
    174
    Look at Spider Cool, it is an aftermarket programmable coolant system. It costs but it would be easy to get up and running and has more functions than the haas unit, it has a option for peck drilling that keeps the coolant aimed at the hole thur the hole stroke of the drilling cycle. That is the coolest feature I have seen.
    Are you aware of the SpiderCool programmable coolant nozzle? Once set, it will automatically direct the coolant stream precisely at the cutting edge of each tool. It also has the ability to oscillate the coolant stream. Add a higher pressure pump, which you can purchase from Graymills or Grainger, and now you have a programmable high pressure coolant nozzle. Can be seen at www.spidercool.com
    Gary
    Jul 2020
    Re: Mini Mill coolant presure
    Quote Originally Posted by engine tech art View Post
    Art
    Art
    Art, Many years later I am in the same situation you were in 2006. Do you happen to have a print of what you made to improve the coolant pressure & volume?
    Regards,
  1. New Haas Super Mini Mill (Odorless Coolant)
    By DREXENG2015 in forum Haas Mills
    Last Post: 10-29-2013, 03:37 AM
  2. Mini Mill coolant sitting and changing mix ratio?
    By Terry G in forum Haas Mills
    Last Post: 09-14-2012, 08:42 PM
  3. Mini Mill Coolant Questions
    By jewells in forum Haas Mills
    Last Post: 09-09-2009, 03:09 PM
  4. Mini Mill Coolant Return Problems
    By knkprecision in forum Haas Mills
    Last Post: 05-23-2009, 02:04 AM
  5. Super mini mill/coolant tank
    By taylors in forum Haas Mills
    Last Post: 02-20-2007, 02:33 AM
