585,975 active members*
4,903 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 0i-TC CRC ERROR! while LOADING GRAPHIC SYSTEM.
Results 1 to 9 of 9
    Jun 2013
    62
    Hello all,
    We are facing a problem in a turning center with 0i-TC control.
    When we switch On the machine, machine comes to LOADING GRAPHIC DATA screen but stops there with CRC ERROR! as in attached pictureAttachment 219234
    After switching ON/OFF for several times machine boots up, but machine hangs after 10-20 min.
    While machine hangs Cycle can be run but we can't operate MDI key board.
    What we have done already..
    1.Disconnected all connectors from motherboard but problem remains the same.
    2.Took out Display control card, CPU, FROM/SRAM card after cleaning inserted again but condition same.
    Please help here................
    Sep 2016
    9
    Re: Fanuc 0i-TC CRC ERROR! while LOADING GRAPHIC SYSTEM.
    Hi!
    We recently facing the same problem. How do you resolve it?
    Would appreciate if you could share the solution. Thanks!
    Quote Originally Posted by jjlong733 View Post
    Hi!
    Hi have you replaced the battery at the back of the screen pannel?
    Sep 2016
    9
    We didn't changes any battery.
    Quote Originally Posted by Adrenalin831 View Post
    I have the same alarm CRC Error . Can You help me?
    Hi!
    I have the same problema how do You fix?
    Quote Originally Posted by jjautomation View Post
    Hello all,
    I have the same problema CRC Error on Fanuc OiMB how go You fix? Can You help me My email [email protected]
    The phenomena are sometimes either displaying nothing or having a creen of "CRC ERROR". Please check your Display Card.
    Jan 2023
    Hello, I am facing the exact same issue. Would be great if you could share the root cause and the solution that fixed this issue. Contact me at [email protected]
  1. Fanuc 6T system error
    By salmve in forum Fanuc
    Last Post: 09-10-2020, 07:38 PM
  2. Fanuc system 9 loading "hang"
    By waterfall in forum Fanuc
    Last Post: 07-26-2017, 02:03 PM
  3. SYSTEM ERROR 998 (Fanuc 6MB)
    By HouTX in forum Fanuc
    Last Post: 11-30-2009, 05:03 AM
  4. fanuc 6m has system error 402
    By runlean in forum Fanuc
    Last Post: 01-23-2008, 03:59 PM
  5. Fanuc 6 system error 908
    By hidivsultan in forum Fanuc
    Last Post: 06-23-2006, 02:43 PM
