Can dolphin output in Arcs instead of line code. I was trying to do single point thread milling and the generated Gcode was so large that I could not fit it on the machine and I had to DNC it. The problem with the DNC was that with all the little movements the controller does not seem to have a far enough look ahead to be able to keep up so it slows the feedrate way down in order to buffer it. So I have a large program that should only take a couple of minutes to run but now it takes 17 min run.
