I am trying to edit a tool change macro on a Mori horizontal with an MSC502 control. When I attempt to change the parameter 3202b4 I am given a "write protect". Write enable has been turned on. I am able to unlock/lock the 8000 parameters, but not the 9000 following the below process:
Mode=mdi
parameter write enable = 1
parameter 3202b0 = 1 or 0....Works fine, no alarm
parameter 3202b4 = 0...Write protect alarm
This is the first I have run into this on a Fanuc control. Is there a way around this?
Thanks in advance.
