586,000 active members*
4,898 visitors online*
    Jan 2010
    10
    Mori Seiki SL2 damping program
    Hey Folks,
    We have Mori Seiki SL2 1980 with Yasnac 2000G. It will randomly dump sequences in the program while making edits. Sometimes it is fine.
    Any ideas?
    Thanks, M
    Aug 2011
    2517
    if you mean sequence numbers like N10 etc there is a parameter for it to add N numbers or not when adding lines. edits dont add the N numbers but if you add a line it'll add a N to it if the parameter is set.
    if you mean it is adding other random stuff then something is wrong with your controller.
    Feb 2009
    6028
    Possible bubble memory failing. I dont remember any parameter for sequence numbers in a G control, think that was added in the G2 control with CRT.
  1. Mori Seiki ZL-253 program setup
    By MGood in forum Fanuc
    Last Post: 12-18-2021, 08:15 AM
  2. Did Mori Seiki Buy Hitachi Seiki?
    By Billet Sean in forum Mori Seiki lathes
    Last Post: 05-05-2011, 04:12 AM
  3. mori-seiki
    By ron2008 in forum Mori Seiki Mills
    Last Post: 10-08-2008, 09:22 PM
  4. Mori Seiki Sub program
    By adaptaflex in forum Fanuc
    Last Post: 06-20-2006, 10:03 AM
  5. Mori Seiki Sub program
    Last Post: 06-19-2006, 02:59 PM
