Hi!
Is it possible to change the value of RDIF parameter for each axis (XA, ZA, XB, ZB)?
I need to find the problem in ballscrew. In this case I want to manualy change the RDIF value to get the alarm error during the axis moving.
The lathe will work in test mode (withowt detail) until the error appears.
(RDIF it is the difference between the actual position and the calculated position).
