585,712 active members*
4,170 visitors online*
    Jan 2011
    49
    editing g-code
    Hello, I need to make some cutting modifications, what I need to know is when I need to cut a piece of material that is longer than my work area and then I need to move the material so that it could continue to finish the job? I know by using notepad I can cut and paste and move the program but being a rookie I would like to get some professional advice. Thank you
    Jan 2006
    2985
    Have you ever seen an instructional book on G-code? They generally suggest drawing out your part, then sketching in the toolpath, then writing code for each segment of your toolpath.
    I write toolpaths on a daily basis with a piece of scrap paper and notepad. Just do an air cut first and hug the estop if you aren't confident in your programming.
  1. Editing G-Code File
    By Kiwi in forum G-Code Programing
    Last Post: 06-17-2013, 10:59 PM
  2. opeing G code file for editing
    By billwann in forum SheetCam
    Last Post: 11-18-2011, 04:31 PM
  3. Editing free g-code file????
    By fsa in forum PTC Pro/Manufacture
    Last Post: 11-01-2010, 04:35 PM
  4. Editing G-code
    By Jonne in forum Machines running Mach Software
    Last Post: 12-27-2007, 05:19 PM
  5. EZTrak editing G code
    By Gncc50 in forum Bridgeport / Hardinge Mills
    Last Post: 11-18-2007, 05:15 PM
