586,009 active members*
4,938 visitors online*
    Jan 2014
    Keep blowing fuses
    We are using a large CNC filament winding machine and we are having a problem of blowing fuses. These fuses are large and expensive and we need to figure out why they are blowing. It seems to happen when we start up the drive motors. Any thoughts on how we can diagnose and fix the problem quickly? Thanks.
    Jun 2004
    511
    Get an Amp clamp and figure out what is drawing to much current.
    24221
    If it is the main fuses for the drives, try and disable each drive in turn at power up in order to zero in if there is one causing the problem.
    Al.
    Albert E.
  1. Blowing 20a fuses!
    By fgwilson99 in forum Community Club House
    Last Post: 04-28-2011, 02:13 AM
  2. Blowing Z axis fuses on 6MB
    By moldmker in forum Fanuc
    Last Post: 08-30-2008, 05:34 AM
  3. Blowing 4amp Fuses
    By tajord in forum Hobbycnc (Products)
    Last Post: 02-27-2007, 02:03 PM
  4. Blowing fuses
    By kaderick in forum CNC Machine Related Electronics
    Last Post: 12-05-2006, 06:34 PM
  5. Blowing the fuses
    By rocks101 in forum Hobbycnc (Products)
    Last Post: 02-26-2005, 10:00 AM
