I just purchased this sainsmart 3 axis cnc control board from amazon. I followed the directions for setup (since it came with no documentation i had to resort to youtube and google to find the relevent information), However i have no movement or holding current on my x axis. my y and z axis both work fine, i have tested my lpt1 port and determined that i do indeed have 5 volt logic. as that was suggested in another thread. all my axis have the same dip settings (althought that shouldn't effect the motor at a stall.
im not too worried about the mach 3 side of things because even when i purposefully set up the y or z axis wrong they still hold there place. so it shouldn't be a setting error but to be sure ive tried powering up the board without the pc connected to see if the holding current would stay but sadly all motors go inactive.
so since i know that the motor isn't activating this leads me to believe that it has to be an Opto coupler or the toshiba stepper driver chip. has anyone else experienced this particular problem? im not sure which of the optocouplers are connected to the x axis and i dont want to venture forth completly blind. does anyone know which opto couplers i should test ( and maybe a good way to test them).
well im all out of ideas im hoping that someone else has had and overcome this problem before
any help would be appreciated\
Nicholai
