585,991 active members*
6,467 visitors online*
Results 1 to 8 of 8
    Nov 2012
    130
    Initial setup of used tormach?
    I've got my used 1100 sitting in my garage.
    I had to remove the Y and Z steppers to get it here. According to the manual I need to run each axis with the steppers a bit loose so that they center then tighten them up.
    It was never used with coolant so there is cutting oil everywhere, plus lots of plastic shavings - it was used mainly to cut plastics when used at all, so I have that mess to clean up.
    I need to reassemble the sheetmetal "wings" with silicone.
    I need to do a basic levelling (the manual says not too important)
    What other basic setup steps or checks should I do prior to use?
    TIA.
    Ken
    Nov 2005
    218
    If you have the power drawbar I'd suggest going through the "calibration" procedure.
    Nov 2012
    130
    No drawbar unfortunately.
    Should the machine to base studs/nuts be tightened down to a specific torque or just snug?
    Nov 2005
    218
    I did not take my machine off the stand to transport it, but the stand assembly instructions do not specify a specific torque. They just say to start the bolts but to wait until you verify alignment before tightening them.
    Mar 2009
    1863
    I didn't tighten the nuts on the stand on my machine. I just ran them down until they were finger tight then I adjusted the feet on the stand to level the machine. It's been like that for almost 3 years and it works just fine.
    You can buy GOOD PARTS or you can buy CHEAP PARTS, but you can't buy GOOD CHEAP PARTS.
    May 2013
    63
    You probably want to check the tram of the head with an indicator on the machine table. Mine ran out a mile and that's when I found out I had loose gibs and a crooked head. (The machine's as well as mine...LOL) With a LOT of prying and tweaking, I got it from .012" over a 7" diameter to around .001"
    I hope the previous owner of your machine didn't hammer it like mine.
    Nov 2007
    2151
    Quote Originally Posted by Steve Seebold View Post
    Hi steve,
    Is this to avoid tension on the machine base casting?
    Do you think this might effect the precision of the machine?
    I was thinking rigidity when I tightened everything down, didn't consider tram or other problems it could cause.
    Would you loosen them now?
    widget_maker
    Some of the oil I bet you see is the way lube, my machine pools way oil under x & y axis and back Y axis way cover below z axis.
    I don't mind I figure it is well lubricated.
    md
    Apr 2013
    99
    Leveling is about as much of an issue as it is for a knee mill, supported at all 4 corners, and so it drains.
    Clean it make sure the lube system is working right
    use a good silicon like black stuff on the base and don't be stingy.
    That's pretty much it unless it was abused, it should work fine.
  1. Kflop/Viper/Sharnoa (Initial setup)
    By Scott M Graves in forum Dynomotion/Kflop/Kanalog
    Last Post: 08-18-2013, 08:10 AM
  2. Newbie Q regarding initial setup
    By czralv in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-12-2013, 03:10 AM
  3. Newbie questions on moving past initial setup
    By chris2112 in forum K2CNC
    Last Post: 02-15-2011, 08:22 AM
  4. Help in initial setup.
    By hjl4 in forum Viper Servo drives
    Last Post: 01-18-2011, 11:20 AM
  5. Gecko540/Mach3/initial setup check
    By zeeway in forum Gecko Drives
    Last Post: 01-18-2010, 06:47 PM
