585,930 active members*
3,715 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > G141 Sub spindle Z axis questions (parameters)
    Jan 2014
    18
    We have an LU15-w with OSP E100L controls. The parameters got wiped and no backup disk. Trying to get everything back to normal. I got it running again, but now when using G141 to select the sub spindle, the Z axis is the same as from the main spindle. (Positive Z movement is towards the Sub, not away from it.) I was wondering if there was a parameter for this or is it something to do with setting zeros? Thanks.
    Nov 2010
    89
    The back up disk should be in the electric cabinet on the back of the machine
    Jan 2014
    18
    Its not in the electrical cabinet.
    Jul 2010
    287
    Were you able to solve the issue?
    Jan 2014
    18
    Yes, I got it solved. On my machine it was optional parameter 35 bit 6. Something about mirroring Z axis for subspindle... I forget actual wording. Funny thing is I found this a few days ago and tried to change it but it requires a power off restart to change. The part I missed a few days ago is you have to hit "back up" on the menu BEFORE powering down.. I finally read the actual alarm message for "Power on parameter change".. go figure... Live and learn..
  1. Replies: 6
    Last Post: 02-04-2014, 10:50 PM
  2. KL-100 Milling Spindle Parameters
    By aulie2 in forum Automation Technology Products
    Last Post: 02-11-2012, 06:55 PM
  3. Replies: 1
    Last Post: 08-24-2011, 06:02 PM
  4. TOOL settings, basic questions - parameters
    By expart in forum BobCad-Cam
    Last Post: 08-30-2010, 12:53 PM
  5. TC4 Spindle Parameters
    By emvali in forum Bridgeport / Hardinge Mills
    Last Post: 03-31-2009, 06:38 AM
