585,974 active members*
4,256 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Experianced this? Z axis sensor NOT working when.. located at outmost X axis area?
    Oct 2008
    47
    Z axis sensor NOT working when... located at outmost X axis area?...
    An how come?
    It wouold be logical to gues that the wire connected to the Z axis sensor is broken at a spesiffic point, so that it the z sensor looses contact when the spindel has crossed a certain point in the X axis. (All the wires from the spindel and the Z axis stepper are deformed/bended when the "spindel and the Z axis stepper" travel along the x axis)
    but:
    When I run it to the top of the Z axis manually, the sensor WORKS at any X-Y location.
    The Z axis "Stop-sensor" doesn't seam to work when i hit the button called "Home" on my controller/contoll-card.
    When I hit this "Home button" The machine is supposed to go to home on every axis and be stopped only when incountering the stopp sensor.
    What happens when I hit home is:
    It runns to the top of the z axis (physical z-0 or, Z origin)
    but then, rather then continuing homing the other axis, x and y, it ignores the sensor, and the z stepper is jus screaming and houling, trying to pull the spindel further in z > 0 direction.
    Have anyone experianced this?
    Oct 2008
    47
    Ok, I did some practical testing of the cables, and the random "working/notworking-reaoults" i get confirmes that it must be one of the wires thet are broken.
    This is the machene: CNC Router (6090) - CNC Router (6090) Exporter
    My question now is:
    Is it the wire from the sensor, or the wire to the stepper (im thinking maby the stepper does not get a certain stopp signal due to a broken wire...??)
    Feb 2014
    Does your machine not have a hard stop safety feature?
  1. 5 axis breakout board and 3 single axis drivers tb6560, not working
    By MROX15 in forum Stepper Motors / Drives
    Last Post: 11-06-2013, 07:34 PM
  2. Anyone located in the SF Bay area?
    By Megaplow in forum Mentors & Apprentice Locator
    Last Post: 01-08-2013, 08:03 AM
  3. Mazatrol T32-6 PLG C-Axis Sensor
    By Karsue in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-27-2011, 03:11 AM
  4. Touch Sensor Z Axis?
    By Ezra in forum Joes CNC Model 2006
    Last Post: 12-14-2010, 09:03 PM
  5. Z-Axis depth guide sensor ?
    By deleteallusers in forum Mechanical Calculations/Engineering Design
    Last Post: 07-17-2007, 06:38 AM
