Re: Slowing down turret rotation
I don't normally run into parts where a few seconds of cycle time makes any difference at all, if it could just run at the speed it does when manually indexing it would give me some piece of mind. Any ideas?
hy, a bit late, i know i just saw this thread after i posted something similar
lb4000 is heavier, and i have it's little brother, the 3000 i focused on same issue; here :
... 1) less rotation speed on the turret, as descibred in this thread
... 2) "heavy tool" setting from parameters page check availability of this option for your control
... 3) selecting rotation sense / direction for the posts that deliver greater shocks when indexing
...... this is good when machining more parts
...... pls see last post in here : http://www.cnczone.com/forums/okuma/...olholders.html
... 4) a nice one for "heavy tools" would be less hidra pressure during coupling, and increased after that; however, not possible on default cnc
(1) decreases shoks a lot, but something still remains
during a setup, i was not satisfied with the result, even after (2)
(3) almost eliminated shocks all the best
