I just sent out an update and had about 10 "undeliverable" due to email addresses not existing anymore and other things. If you have purchased the plans and have not received an update, PM me your name and email address you used when you bought the plans. If I find you on the list I will update your information and get you the latest set.
I found out a few weeks ago that the distributor gear set I used was supplied by Berg who now has a $200 minimum order on online orders. I found new sources for the gears and seals. The drawings were updated to work with the new gears and over all should save you about $90 in material costs.
